Halogens can have them as well as xenons, so can't be used to tell.sam1832 said:Do you have head light washes?
a11y said:Simple way to tell:
- xenons don't have a numbered height adjustment dial next to the headlight switch
- halogens don't
I'm confused myselfmrlozzer said:a11y said:Simple way to tell:
- halogens don't
I'm confused a11y...oke:
a11y said:I'm confused myselfmrlozzer said:a11y said:Simple way to tell:
- halogens don't
Should read:
Simple way to tell:
- halogens do
Huz-z said:My 3.0si came from the United States and while it has zenons, it does not have headlight washers. The North American regulation on that must be different than the European rule.
Wondermike said:The easiest way to tell - can you see anything at night?
Yes = xenon
No = halogen
:tumbleweed:
Yes = xenon
No = halogen
:tumbleweed:
garbage!!john56 said:Wondermike said:The easiest way to tell - can you see anything at night?
Yes = xenon
No = halogen
:tumbleweed:
I will second that, halogen = useless.
Yes = xenon
No = halogen
:tumbleweed:
VvrooomM said:garbage!!john56 said:Wondermike said:The easiest way to tell - can you see anything at night?
Yes = xenon
No = halogen
:tumbleweed:
I have Halogen in my 2011 Spyder and nighttime visibility is excellent. I was worried as I'd thought xenon were standard and bi-xenon were cost option only to find it was either halogen or bi-xenon option.
The light is not as white but with full beam, visibility is as good as needed for the speeds the car is capable of.
I have halogen on my 2006 coupe and they are useless.
Tapatalking on my iPhone.......
