Headlights fogging up inside after rain or washing. its normal or a sealing issue?
AutoPilotAgnes
 Poland
The strange part is that the condensation doesn’t stay permanently after some time (usually a few hours or sometimes overnight), it gradually disappears on its own and the headlights look clear again. However, it keeps coming back every time the car gets wet, which makes me think something isn’t quite right.
I’ve carefully inspected the headlights from the outside and I can’t see any visible cracks, damage, or broken seals. The lenses look intact, and there are no obvious signs of water ingress points. The car itself hasn’t been in any accidents, so I don’t suspect any major structural damage.
Still, this situation is starting to concern me. I know that a small amount of condensation can sometimes be considered normal due to temperature changes, but I’m not sure if this level and frequency is acceptable. My main worry is that over time, repeated moisture exposure could affect the electrical components inside the headlight housing, such as connectors, bulbs, or control modules, and potentially lead to corrosion or failures. While trying to understand what might be going on, I was also looking into how headlight assemblies are built and what usually fails first in cases like this, including seals, vents, and housing joints. I ended up browsing parts diagrams and replacement options on autodoc just to get a better idea of how complex (or simple) a potential repair might be, especially if it turns out to be just a gasket or vent issue rather than the whole unit.
So I’m trying to understand whether this is something typical that many owners experience and can safely ignore, or if it’s more likely a sign of a failing seal or ventilation issue that should be addressed sooner rather than later.
Has anyone dealt with similar headlight fogging? Is there a reliable way to identify whether it’s just normal condensation or a genuine leak? And if it is a sealing issue, what’s usually the best way to fix it without replacing the entire headlight assembly?
Mine on both Z's cured with new rear covers. Dry em out with a hairdryer, easy job.
I recently drove through a massive puddle and the headlights fogged up but has slowly disappeared. I'm assuming some water was forced in past the rear cover seals.
