Hello!
No sooner have I had my suspension arms, bushes & tracking done (and replacing my nicked stubby!), there's now something else to sort! Though I suspect this may be because of the cold weather.
My headlight washers are sticking out from the bonnet, the driver's side in particular.
Driver's:
Passenger:
A gentle-ish push on both doesn't do anything - they won't go in. Now, I've read this thread from last winter, which was quite helpful. I can't see any fluid coming out of them when I use the windscreen washers, though it's difficult to see on your own! I'm only using plain water too - ran out of screenwash.
Adding all those up, does it suggest that the water in the headlight washer pipes/whatever is frozen, rather than them being broken?
Should I just wait for it to warm up? Will it do any damage leaving it as it is?
Add some screenwash and hope it mixes to clear it?
I'm just not fully convinced it's frozen because the windscreen washers are still working fine at this temperature. Or does engine warmth heat those a bit better than the headlight ones, being closer?
Cheers guys!
Driver's:
Passenger:
Cheers guys!
