cj10jeeper said:
So did you buy a headlight with a crack in it?
Seems regardless you have to take it off clean it and dry as best you can, refit with. EE cover and seal and search for a replacement.
Agree though that spec is hard to find
Yes, as outlined in the original post, the lens isn't cracked but a bit underneath was slightly damaged. In fairness it didn't start showing any signs of condensation till it got really cold. It was only £60 so I wasn't expecting perfection, but if the seal repair works then i'm laughing. If not, I can use the internals and lenses on another light.
Irritatingly i've had countless niggly problems with this car and every fix has seemed to present more problems - when do I get to start enjoying it and driving the 'ultimate driving machine' you all wax on about?
