Hi,
My 2004 Z4 3.0 has headlamp washers which don't currently work correctly. If a separate 12v supply is connected to the washer motor, all works as it should, so the pump and pressure side are all OK. When the washer switch is activated, connected normally, I only get a brief 12V supply to the pump, which isn't enough to activate the washers.
Can anyone advise where the relay for the headlamp washers is located and what colour it is? - I guess that's my next port of call - any other feedback or ideas would be welcome.
Many thanks.
Many thanks.
