Head light washer pipe “C” clip
PDJ
 Worsley Manchester
Does any one have the little clip that goes on the head light washer pipe.
It looks like a “C” clip in shape around 12mm diameter
It fits over the pipe snap/push on connection between the headlight washer pump and also the two washer jets
I have lost one
Or does someone who has one and the ability to 3d print one
I'm sure I have both the pipes that go from the "T" piece to the washer jets, just not the pipe between the "T" piece and the pump.
I'll have a look in the shed tomorrow and confirm, but in the meantime let me know how much of that you need/want. If you literally just want one clip I'll post it to you for free. :thumbsup:
I have lost the one that was on the tee to the drivers side washer so swopped the one on the pump to save removing the bumper again so as far as I can tell I just need one clip, if you have 2 clips that would be great just in case I am daft enough to loose one again.
I'm pretty sure there were 2 clips but I'll let you know for sure tomorrow when I've had a look.
