Buy a piece the same length as the edge of the window and just push it on. Car Builder Solutions supply this kind of thing for kitcars etc. Ducklakeview said:That looks pretty normal to me - Don't forget, there will be a bead of "panel sealant" underneath accounting for the little "step" between the panel edges.
Did you check the big grommet?
Mike
Ala5dair said:Ducklakeview said:That looks pretty normal to me - Don't forget, there will be a bead of "panel sealant" underneath accounting for the little "step" between the panel edges.
Mike
Mike,
I looked briefly for the grommet, but it wasn’t obvious, and as the carpet is also wet on both sides of the opening, I didn’t think this was likely to be the cause. The car is covered at the moment, but I’ll have another look tomorrow.
PS - I’d like to arrange a roof motor relocation in the near future, and I wonder if you can do a cdv delete at the same time? I’ll email you once I have a timescale, and once I’ve driven the car more than 50 miles in one go...
patriot66 said:Hello and Welcome to the forum. Car looks great. It just needs a little TLC. My old 3rd brake light in the bootlid leaked as it was cracked and the seal perished. Also check the neoprene foam gaskets on the reverse of the rear lights for perishing. From your photo it looks like a chip/damage to the lower edge of the hardtop rear window. I doubt this is the source of any leaks as the hardtop seal itself sits on the bodywork and prevents any water ingress. You could 'hide' that damaged glass edge with a length of rubber u-section panel trim like this :
0017109_115-x-6mm-rubber-u-channel-for-3mm-panels-per-metre.jpegBuy a piece the same length as the edge of the window and just push it on. Car Builder Solutions supply this kind of thing for kitcars etc.![]()
Ducklakeview said:Ala5dair said:Ducklakeview said:That looks pretty normal to me - Don't forget, there will be a bead of "panel sealant" underneath accounting for the little "step" between the panel edges.
Mike
Mike,
No probs, can have a look at the water leak as well if you want.
Mike
Mike
The black rectangular air vent (featured in your last pic) are a common water leak. There's one on either side of the car and I think they have a seal/gasket that fails. Remedy IIRC is either new vents or some sealant to stop them leaking around the edges.Ala5dair said:Ducklakeview said:That looks pretty normal to me - Don't forget, there will be a bead of "panel sealant" underneath accounting for the little "step" between the panel edges.
Mike
Hi Mike
I’ve spent the morning disassembling the rear of the z.
Is the grommet you mention as shown in the photo below?. If so, there are 2 and they are in place and intact.
Returning to another possibility, there is no sealant between the two panels either side of the boot opening, meaning water passes between them, (shown.by the double-headed arrow), and there is a gap between these and the light housing, which means that water pours directly into the cavity where the lights are mounted. There doesn’t seem to be any ingress via the lights themselves, but it seems to be entering the light trim mounting holes and then getting in via the rear
On the kerbside, it’s also getting through the grommet for the parking sensors, on the rear inner panel
The car is drying out, and now that I think I know the cause, I can address it, but I’d like to understand the supposed route for water that enters the boot rim. Should it pass as it does, between the 2 horizontal panels and then out between the inner and outer rear quarter panels, or should it flow along the boot rim channel and then out over the rear bumper?
Can’t anyone advise the best way of solving this problem?
I could silicon all of these gaps, so that water runs down the boot rim and over the rear bumper, but this might look a bit messy and cause problems elsewhere.... Any and all advice welcome...
Ala5dair said:Thanks, all for the comments. It makes sense that, with the slight glass damage, water is getting under the hard top, into the soft top and then, if the drains are blocked, we have the issue. I’ll check the drains and advise ASAP.
Unfortunately, the posts with the drain cleaning instructions either seem to be obsolete (shipkiller) or the photo’s are removed (sixspeed). As a newbie, I’ve no experience of the car, and so I’d really appreciate it if someone could advise where I can see the photo’s too.
Ref the wheels, they’ll be tested tomorrow, and I’ll update once I know the true situation. Fingers crossed...
