tintoverano said:bluesun89 said:10 days ago my roof stopped 90% through on the opening sequence, and had to turn off/on engine and try reclosing/opening to make it complete the cycle eventually. Issues seems either at like 90% of the opening sequence (when only windows need to come up, and boot almost closed), or 80% of the closing sequence (when rear window is on top of roof and needs to go back to its position)
this happens if the battery is not charged enough and there's not enough juice to finish the operation
if you don't have any fault codes, I wouldn't worry about it right now
if your dealer is not specialized in roof issues, you won't get far
But then, shouldn't such roof issue go away when the engine is running ? (car idle)
And this wouldnt explain why I have also been getting random 'red' roof button lights (and sound) while driving, no? (and it also locked down the boot and windows while the red light is on)
I'm afraid to try again and end up not being able to close it back (and alarm going off etc..)
