Hardtop controller failed no roof and no boot open
birdy_z4
 Warwickshire
Hi All
Got this error message Hardtop controller failure
Hardtop lights on switches do not work
Boot will not open with key or with the latch on the boot
ATTACH]
Any advice appreciated
Few just been back to the car and it seems to have reset itself no error warning, roof and boot now working
Microswitches can be intermittent. Plenty of knowledge on here and not too expensive if just a switch(es) replacement.
You might find the fault kicks in again, but see how it goes.
Arghhhh, this had happened again today .....
Any way to trigger the boot release with ISTA D on INPA?
Remote trigger - not that I have seen TBH.
Did you check your battery? Last changed date & milage are recorded in your ECU.
So just checked and ista d cannot connect to roof module and boot lock is not opening with boot partially open
How can I get the boot open if I cannot access the roof module?
looking at this thread it appears i may have to try this
https://z4-forum.com/forum/viewtopic.php?p=1967769&hilit=boot+open#p1967769
pin12 and power ....
Ok so used the FRM pin 12 and blue fuse which worked a treat.opened the boot
Wires checked and all now working :D
Hi birdy_z4. What kind of smart roof module have you used? I have cabrio-module.de and now it stopped working too. And worked the trick with "pin 12" to open the boot? Thanks and have fine day! :driving:
