Hardtop Allen Key - replacement SOLD OUT
mac27040
Shepshed
Hi All,
just what to gauge interest in who would be interested in buying one of these, not sorted the price out yet.
this is the copy of the original
approx 10cm x 9.5cm
is it a 5mm allen key? I don't need one for hardtop but for Monkey's exhaust tips. The one I have is getting shredded (weak metal).
Will these be made of cheese if so?
It's not a 5mm Allen key, if you have a hardtop then you may want a spare. If you don't have a hardtop then you don't need one.
Surely a normal allen key of the correct size is fine for the middle point, the rears you just need a screwdrive or something to put in the hole and turn.
Failing that, where are you located and someone may be able to assist?
I used normal Allen keys when fitting/removing my hardtop, but that's only because I kept misplacing the oem double ended tool, so yes, normal Allen keys are perfectly fine to use.
Go careful with the 2 side locks and using screwdrivers. If you poke it through the hole too far you will catch the end of the rear window glass, which finishes just by the lock mechanism - and end up grinding away some nice glass powder when you then turn the lock.
Timmyboybunter said:
If @mac27040 can still supply, I'd be interested in one just to further my anal collection of hard top bits :)
Where you keep the Allen Keys and hardtop bits is entirely up to you! :rofl:
