cj10jeeper said:I think you're going to end up chasing your tail on this and replacing half the car without proper diagnosis.
If you've done the obvious and checked for disc & pad wear, even contact on discs ie no missed parts in sweep, tyre pressures correct, tyre wear left to right wheels even. All checked on front and rear and done your brake testing on different surfaces, such as a big car park, then I'd take it to a station with an MOT style brake tester and that will in 2 minutes to confirm or eliminate all brake issue. You can then either repair or focus on all the more complex stuff of bushes, alignment, suspension, damaged parts, etc.
IMHO it's nothing to do with calipers sticking as this replicates at all speeds nor collapsed lines as that gives mushy or no brakes. Lollipops are possible, but part 3 first
ph001 said:DS2500 are a well known and recommended pad. I'd rate them over Redstuff but not as good as Performance Friction Z rated pads (0558.11 = front, 0396.11 = rear)
ph001 said:I run the same PF on the M3. They are very low dust as well.
Ed Doe said:That machined indent in the disc is normal and iirc is to mark the minimum thickness of the disc after which it needs replacing. Entirely normal and if you look hard enough it'll be on all the discs.
My money is still on worn bushes and poor alignment!
R60BBA said:Okay so after calling around I’ve got a few quotes for replacing discs, pads, lines, sensor and fluid.
- Munich Legends - £700 :? but £220 if I don’t change lines
- Evolve Automotive - £327
- TWG Automotive - £200
- BMS Leatherhead - £180
- ETA Motorsport - £250
- Birds BMW - £350
Interestingly Will at TWG did not recommend using EBC Redstuff pads nor Goodridge lines, stating that the pads have poor bite and the lines can leak. Instead he recommended using Ferodo DS2500 pads and HELL lines. (I presume he notified this to me because TWG provide a 1 year warranty on all work done by them and so need to be satisfied that the parts they fit are up to standard.)
Anyone had any issues with EBC Redstuff? Or should I take his advice and go with the Ferodos.
(I believe the difference in price between the 2 pads is roughly £100).
patriot66 said:That machined indent on the edge of the disc is definitely factory balancing. To be honest with you although there is a fair bit of metal left in them I don't think those discs look in particularly brilliant condition![]()
I'd fit some new discs and pads and bet it makes a world of difference ! I fitted new Brembo discs and pads all round on mine a few weeks ago as I was having all sorts of issues with the MTEC/Red Stuff combo I was running. Now the Brembos have bedded in the difference is night and day....much, much better !![]()
R60BBA said:patriot66 said:That machined indent on the edge of the disc is definitely factory balancing. To be honest with you although there is a fair bit of metal left in them I don't think those discs look in particularly brilliant condition![]()
What was wrong with your Mtec/Redstuff combo if you don’t mind me asking.
jack07 said:Hi R60,My threepenneth on this is listen to Ducklakeview,as those front lower wishbone bushes may not appear worn and may be entirely passable at m.o.t.but upgrade them to a polybush and this eliminates the horrible braking wander that ruins these great cars.Then when the polybush bug bites,do change the rear trailing arm front bushes next to tighten things up nicely.Don't be put off the Redstuff pads,as mine have been excellent in every way for the last 20 thousand odd miles,plenty of meat still on them and have not carved into the discs as I expected.There is no discernable wear lip at the disc edge yet so I recommend them and will buy again when the time comes.The only negative I found was the bedding in time being rather longer than usual.Good luck with however you go![]()
