B bp1z4m Member May 11, 2009 #1 i seem to get varying amount of handbrake travel when i apply the brake. some times it's three clicks,others times it can be as many as six or seven, does anyone else have this problem ? never happened on my 2.5 i had . :?
A Andy Veteran Warwickshire May 11, 2009 #2 Yeah mines pants, first thing I took it to the dealer for 3yrs ago, but never much better. My top tip - pull it up fully with the button pushed, then lower it. Then do it again and it should be a lot tighter on the second go.
B bp1z4m Member May 11, 2009 #3 thanks i will try that,its just that the m.o.t is due soon,i was wondering if that would cause a problem with the test ??
mmm-five Lifer Liverpool Site Supporter May 11, 2009 #4 The first time I apply mine after a run, it will take up tp 6 clicks. When I release and re-apply it seems to be only 3 - is it self adjusting?
S sammyz Veteran Merseyside May 11, 2009 #5 yeah, mine's rubbish. Won't hold on a hill. Sometimes 6 clicks sometimes less but always poor performance!
G ga41 Veteran Paphos May 11, 2009 #6 mmm-five said: The first time I apply mine after a run, it will take up tp 6 clicks. When I release and re-apply it seems to be only 3 - is it self adjusting? Click to expand... Had the exact same thing last night after a rather spirited drive.
S scottie1979 Member Glasgow May 11, 2009 #7 I find if my foot is on the brake then it doesn't travel up as much
