Guide: Replacing Water Pump and Thermostat - E89 N54 (and radiator)
Angel_e39 said:
Thanks for your help I really appreciate it
I've had zero luck finding any tutorials or step by step for the n20 version. I'm at the part where I need to remove the bolts now so that means my thermostat is out and I've drained the coolant. Hoses on the pump are out as well. Just those damn bolts with the zero access.
I got the wrenches you used in my amazon cart now and if the wrench that's on it's way to me now doesn't work (No flex head) I'll buy yours
Do 12-point work on External Torx bolts fairly well?
Look for N20 videos on 3/5 series’s?
DO NOT use a 12 point in place a proper torx driver..you’ll be in deep doo-doo
FCP EURO has a great video on an n20 but he removed the bolts from the bottom. In my e89 n20 the steering rack is in the way
Very true.. especially on the softer aluminium bolts! etorx/torx socket sets are fairly inexpensive, if yours are torx/etorx, there are flex head socket wrenches as well.
So I ended up removing the steering column since it actually was not that difficult.
Once I removed it I realized that it was a required step no way could I have gotten such a clear shot to the bolts without it off.
I'm going to post two videos that helped me remove the steering rack for others
Here are some pics for the location of the bolts.
:thumbsup:
These look excellent instructions, however, I have an N52 3.0litre.
I cannot find specific " N52 how to" on this forum; can I follow this successfully, or can someone please point me in the right direction?
I am concerned about buying the appropriate torx spanner.
Thank you.
Car is past 130k now and Welsh roadtrip at Christmas planned so keen to replace pump before.
Once again can I ask if this guide can be used for my N52?
I'm sorry Blue, I didn't see this thread light up -- This is certainly specific to the N54. The N20 should be similar in effort, but will have different parts and locations will be different. I've not done this on an N20/N26 yet.
Just planning for the future. Is there a recommendation on a bullet proof water pump? I’m reading it’s the electronics that go bad in these and not necessarily the plastic pieces on the inside. Are the plastic pieces not allowing the heat to “transfer”/escape whereas an all aluminum would allow more heat to escape?
