Guide for replacing old hydraulic lines
Hello guys,
I have found this company in Europe. They purpose:
- a quick coupler to repare a leak
- a kit with 2 coupler and a part of hydraulic hose
- a custom hose with origin plug
Hello there,
I need to change the hoses that go to up to the cylinders of the rear and front shells. Does anyone know the exact number?
I am trying not to remove them until I have received them. I can see that the number 21 goes to one of the shells but I cannot see the remaining 3. Does anyone have this information to share in this post please?
Thanks!
Max
Hello Dave,
can I ask you how you managed to pass through the new harness under the front shell ? did you remove it? or you loosened it?
there harness there does an elbow, so wondering how you passed the new harness through.
The z4 that already had the s676 is leaking, just found out whilst I was inspecting the sound system there!
I have NOT identified the source of the link but I found trails here and there in the roof storage area in the boot (along with the area behind the seat, which I still cannot understand how it could get soaked in hydraulic oil. But it s clear oil so it has to be from the roof system.
there are holes in the car frame (internally) so it could seep through from the boot area. the headlining is not oily, it seems.
I will inspect the wiring as well and if worn I will replace in all of the elbows with industrial heavy duty 4000000 times bents guaranteed!
do you also happen to know the hose numbers of those going up to the shells?
I am buying from them so they want the number. I can see at least 21, so I would assume the cluster 21 through 24 to go the shell.
AnubisZed said:
To anyone thinking of doing this work....... DON'T 🤣
Only kidding :D
Well mine is now done and complete, so I'm a happy bunny. This was to be done the previous weekend but one of the rear roof bolts was stuck solid so had to abandon that attempt and seek engineering assistance :headbang:
So part way through the morning it looked something like this....
And then about 7 hours later it looked a lot like this...
Just needed the aligning doing at this point, but that was for Sunday and is now all sorted.
It is a long job and I'd suggest a certain level of mechanical awareness would be beneficial. It's also back breaking, frustrating and bloody awkward to do. I really wasn't looking forward to doing this one little bit, but considering how much this has saved me in labour costs then it is well worth all the hassle.
Would I recommend doing this yourself, well if you are mechanically minded and really don't mind getting stuck in then yes. BUT, this is not a job you can start and then feel it's not for you and get a mechanic to finish it, this is one job you are just going to have to see all the way through to the end.
So what are we replacing here....
Hydraulic hoses to all 6 rams (12 pipes)
Wires to almost all microswitches
2 microswitches (if your Z is an older one like mine is)
Wiring loom for the hydraulic pump complete (including the relay connection block)
Basically the whole lot excluding some of the microswitches themselves.
At the end of the day I looked at it like this, if one of my 12 hoses has split (however that may have occurred) and my Z is 11 years old, then any one of my other 11 may go at any point, coupled with this they all flex at the same rate along with the wiring loom to the microswitches. This is a very big job to do to replace one hose, so why not just bite the bullet and do the lot in one go, yes it is time consuming but to do it all at once is going to save you having to do it all again next time. So I'm pretty sure I won't have to do any of this again in what I consider will be the remainder of my ownership. Just my thought process :thumbsup:
I have now found the culprit that was the leak in the first place, a slit in the pipe on the leading bend of the drivers side rear roof section...
And a closer look...
Really not sure how this has happened, it's not like it's a location that flexes every time you operate the roof, you can't access this location without removing the headlining, but it is exposed when you have the front roof shell repaired under warranty!! :?
I'd like to say a massive thank you to LordLolzeye for all of his efforts in producing this How-To, it has been invaluable in getting this work completed, thank you sir you are a legend :driving:
You don't need to remove the front shell, only the rear one (with the rear screen in it) and DON'T FORGET to remove the rear screen connections!!!!
On the cabrio site they ask you to phone them, there they'll work out exactly which hose/s you need :thumbsup:
My buddy's car had a minor fluid leak on the driver side. The cylinder and pipe/line was fine but it was leaking at the port. I slide the retaining clip out and removed the pipe/line and seal. The seal looked fine. I did notice that the retaining clip seemed to be 'flattened' so it was retaining, but not providing an axial force. I used a small screwdriver to open up the clip so it provided a stronger wedge. It took more force to reinstall but the leaking has stopped. Time will tell.
The leak is back. I would like to replace the seal. Does anyone know where to get the seal?
I swapped the seal with one from the other side and there is still a leak on the driver side (left side) so it looks like the seal is not the problem. I don't see leaking from the rod seal so I think the hydraulic line must be leaking at the swaging. Looks like I will be replacing all the lines.
I just repaired a leaking hydraulic hose at the bow in roof shell 2 using these hydraulic hose couplers: https://cabriolethydraulics.com/hydraulic-hose-repair-couplers/
It took about about an hour - I cut out the bad section, installed the coupler, and put everything back together. I then refilled the hydraulic fluid in the reservoir near the pump in the trunk - it's self bleeding. All works like new now.
Regardless of whether you attempt a repair, or replace all the hoses, make sure you put the zip ties back *exactly* where they were - I got this wrong while repairing the wiring and the friction from the zip tie is what caused the hydraulic line to burst.
I would like to know which size do you use? 1.8 or 2.0
Hello, first, thank you for all of the amazing information! I tried to order a wiring harness from a BMW parts site and got the runaround for two weeks while they kept changing the price and I finally decided to just build my own harness. I bought hoses from https://www.cabriolet-roof-hoses.co...89-z4-roadster-hydraulic-cabriolet-roof-hoses and SXL flex rated automative wiring from Remington Industries: https://www.remingtonindustries.com...e-stranded-10-colors-7-spool-sizes-available/.
I was able to build the the new harness by drawing the various locations in the old harness where the tape goes, the clips, and the sleeves along with lengths of wire, color of wire, etc.
All went well until I installed the hydraulic line, with a brand new o-ring, back into the cylinder only to have it leak out when I put the retaining clip back on and moved the roof top arm.
I tried to buy new retaining clips but couldn't find any anywhere.
Questions:
1. Does anyone have a part number for the clips (photos below)? Or even better, a source to buy them?
2. Did I put the new o-ring on the hydraulic swange connector properly? I also wiped it with a touch of hydraulic fluid.
3. Anything else I'm not considering? Is there a way to re-bend the original clip to get it to work again?
Thanks Robbi. Any chance you have a photo of a good clip and how it should be shaped to re-use it? It definitely slides in and out real easy now versus it did not want to move when I first pulled the clips. I ordered o-rings to per the spec you list above, but I used the o-ring that came from CRH (where I got the custom made hoses) and figured that would be best. I can swap out the o-rings if you think that's worth trying.
I was looking for new clips because I assumed the old ones were too loose and not holding the hydraulic fitting into the cylinder properly. I did notice that two of the clips have a bend in the center, where the first two I was using were more or less flat. I wonder if put the drivers side ones on the passenger side or something like that. I just figured they'd all be identical. I'll try the other o-rings I bought that match the spec you list. Maybe that's the problem.
I still have all 4 original clips and will try to get them to work.
