Just about to go out in the car and my remote key fob doesn't work.
Opened the car with the physical key and alarm goes off, key fob won't lock the car or turn the alarm off either.
Lock it with the physical key then go and search for the spare key. Same results there with the spare.
Left it for a bit and the keys work fine again
I will check the battery but that should be fine as the car is used regularly plus the battery is relatively new. Just in case I'll put the trickle charge on tomorrow. Battery voltage maybe a little bit low on startup but goes to 14.1 when started so alternator is OK
I'll also check for codes.
So if it is gm5, any recommendations for getting it fixed?
