:scratchhead: gosh does he work for porsche and have one of their prototypes? Given an RS GT4 is unavailable (yet) to the public.Marlon said:My brother's got a GT4 RS
TomK said:The fact they WELDED third gear to the shaft is quite frankly astonishing...
TomK said::scratchhead: gosh does he work for porsche and have one of their prototypes? Given an RS GT4 is unavailable (yet) to the public.Marlon said:My brother's got a GT4 RS
MrPT said:buzyg said:Looks like poor design from where I am sitting. No car should do that. You might expect a damaged tyre, wheel or shock after a vertical impact and yes the top mount might fail but that should be a replaceable part. Are there other makes of car documented with this issue?
The follow up vid is worth watching. A tech talks through the construction of the subframe/strut assembly in that area and why different materials behave differently under sudden impact load. Steel stretches, aluminium alloys fracture, carbon can break internally. All sounds pretty reasonable to me, as does the estimated repair cost/time of £5k and two weeks. I can believe that a lot of people are driving around in bent steel chassis from the number of alignment results you see that don't quite seem right! He also points out that the strut tower damage was likely secondary to a smaller, initial break around one of the bolts (which is much more common, hence reinforcement rings etc on many motorsports/aftermarket top mounts).
With the 718 GT4/Spyder just round corner, it will be interesting to see whether any reinforcement is added from the factory. If not then I'd assume a combination of arrogance/confidence on Porsche's part. They would probably argue that the whole car is built to similar tolerances and there's no reason they'd make an exception for that particular area when, on the customer side, they could be dealing with anything from a parking ding to a full speed spin sideways into a sausage kerb on a track.
Your missing my point John. If some driver, plonker or skilled racer on the limit, drives over a kerb at speed, then yes something is going to get damaged. What I am saying is the point of failure should be designed. Like a fuse in an electrical circuit. The structure should not be the weakest point. That would be like the wire melting somewhere in the ring main. Not good design and dangerous.john-e89 said:MrPT said:buzyg said:Looks like poor design from where I am sitting. No car should do that. You might expect a damaged tyre, wheel or shock after a vertical impact and yes the top mount might fail but that should be a replaceable part. Are there other makes of car documented with this issue?
Wasn’t the front offside the wheel he smacked on a kerb from memory? That kind of hit coupled with low profile tyre and short spring travel could well easily cause the start of a fracture. They’re not meant to be smacked like that, no production sports car is. If the car is used on track with no pre fracture there won’t be a problem. I’m going on memory from the vid so I’ll stand corrected.
Jembo said:How many times have we seen other cars spin violently @ speed, where I thought the recent Z4MC track vid spin was going much faster & no report of damage - the points made my buzgy & myself earlier are whether it’s acceptable for a prestige race thoroughbread to have this kind of failure?
Happens once... hey ho... a number of times & there’s clearly a design flaw, irrespective of whether the drivers are Muppets
BMWZ4MC said:Jembo said:How many times have we seen other cars spin violently @ speed, where I thought the recent Z4MC track vid spin was going much faster & no report of damage - the points made my buzgy & myself earlier are whether it’s acceptable for a prestige race thoroughbread to have this kind of failure?
Tom's spin didn't lift the car and then thump it back down, it was entirely a slide. The GT4 spin was much more violent.
I think the problem relates to the choice of construction material. Porsche have accepted the lesser mechanical properties of aluminium compared with steel as a trade off for its lightness. Perhaps they should have made the strut towers from steel and the non-structural panels from aluminium :scratchhead:
