Baracus (aka Steve) said:gapTech said:Hi, I'll try to answer some of the questions.
The module connects to the loom behind the centre console, 3 wires for the remote only or 5 wires for the combined unit, full installation instructions and connectors are provided with each unit. There is no new remote on your keyring required and you do not need to have your key programmed in any particular way. When you press the unlock button on your existing remote three times about 1 second apart the roof will open and if you press the lock button in the same mannor then the hood will close. A single press of either button when the hood is moving will stop the hood from moving. The one touch feature allows you to just press one of the dash buttons for 0.5 seconds and then release and the hood will continue on its own whilst you manoeuvre the Z4.
top mananswered all my questions perfectly
Cheers mate, just what i'm after![]()
jimbo1958 said:gapTech said:Hi, I'll try to answer some of the questions.
A couple more questions.
1) I presume when closing remometly with key, will it also close the windows if down?
2) Also with remote closing, 3 clicks to close. Does this also lock the car or do I have to give it another click once the roof is closed to lock it?
TIA
17. Pwo OTH +RChristianm said:1. PVR RO
2. PawnSacrifice RO
3. Lob808 OTH+R
4. Moffmo OTH+R
5. Gookah Remote + OTH
6. Dice OTH+R
7. Baracus (aka steve) OTH+R
8. playalistic OTH+R
9. Gargybloke OTH+R
10. Dreamer OTH+R
11. Aquazi OTH+R
12. Mangozac OTH+R
13. Billygilly OTH+R
14. TDZ840 OTH+R
15. Z222M OTH+R
16. Christianm OTH+R
