Well from my understanding of the DME, in terms of the secondary air system, when it wants to activate the pump, it grounds the relay, which allows current to flow through and trip the relay, giving full power to the secondary air pump. Right now, my secondary air pump is not being tripped.. I'll have to look into it further and manually ground it while the car is on and see if it gives power to the pump. If it does, it'll show that the DME is at fault and not giving a ground for the relay when needed.
