Got a chance to buy 19in Alpina alloys… will they fit?
1000rr
Part numbers are
36 11 202 8.5J ET34
36 11 203 9.5J ET36
Tyres are all 245/35/19 93W XL Michelin Pilot Alpin.
Will these fit?
1000rr said:
Part numbers are
36 11 202 8.5J ET34
36 11 203 9.5J ET36
Fronts I would say will be problematic to say the least. I’m on 8J ET 34 405M’s with 225/40/18’s, wouldn’t want to try a wider wheel or a bigger tire
Will these fit?
Same size as the Alpina Roadster wheels, aren't they? But with smaller offset? If so, you might find they stick out too far.
I would do some googling and see if you can find someone who's tried it before.
To be honest, even if they don't fit, you can problem sell them on without losing any money.
1000rr said:
36 11 202 8.5J ET34
36 11 203 9.5J ET36
Will these fit?
I recently fitted 225M's on a car lowered by 15mm and they are fine with 225/35/19 on front and 255/30/19 on rear (Pirelli Zeroes)
your offsets only differ by 3mm, so the rims should be fine - but you may have to drop down to 225 on the fronts
