stuartinzg said:
techathy said:
With the Z4 running rather high neg camber at the rear it may not engage the outside shoulder with the road until you get into big cornering forces so you're unable to transfer that grip into straight line traction.
This is a problem, I just can't get full throttle traction in 1st/2nd, even in dry and 14c. The thing is constantly wheel spinning..
Sounds like my first 2011 35is whereas the current 2014 version is much, much better. Of course it can still leave a trail of rubber behind but once moving it is much better behaved and gets the power down quite nicely only lighting up the dash on undulations/bad surfaces under full bore acceleration. It also tolerates getting on the gas earlier exiting corners/roundabouts - the previous car would wag its tail far too easily and at temperatures below about 7C it required enormous 'respect'. I wonder if BMW made some suspension changes between the two?
