BRISTOLCHINO
Hi all,
I am trying to remove the GM5 unit from my E85 Z4 as the central locking has developed a fault. From watching some videos on youtube, it looks as though you only need to remove the 2 phillips screws holding the panel below the glovebox in place, and the panel just drops down revealing the GM5... However I am having real difficulty in removing this panel as it seems to be catching on something. I have managed to wriggle enough room to lock behind the panel and it looks like the GM5 is not actually located here at all?? I have tried removing the whole glovebox, but again to no avail... I can remove four phillips screws, but it looks like there is a fifth just behind the glovebox hinge which I can't get to.
If anybody else has had a similar experience, I would be most grateful if you could share your wisdom!!
Many thanks
Many thanks
