Glued emblem
mck159
Emblem at my front hood was being glued by previous owner using some kind of hard super glue. It is worn out and I cannot remove it using plastic removal tool using light force and I don't want to push harder. Any ideas, someone had sth like this?
Hairdryer to melt the glue?
There's usually an emergency hairdryer in the boot at least that's what the folk at work think!
Are you sure it's glued as the original ones are bolted and you need to remove the grill to get access to them.
As above remove the grills and check to make sure it's not bolted up, other wise get a short stumpy screw driver in there from behind and try and push it off :thumbsup:
Whatever you do don't try any leverage of the badge against the bumper cover (not that you would)
Are you sure it's not bolted from the inside?
If not then as others have said try from the inside with a punch or similar.
Not being dramatic but to save my paint I'd remove the bumper cover to,work on it from behind, or simply drill thought the badge and break it up and off from the centre.
All depends how well it's stuck down and with what.
