Thanks for the comments everyone - just can't wait to get the front calipers and new discs/pads on as this project has been a while coming after a lot of to-fro with CJ and pawnsacrifice who saved me messing up a couple of times.
Dreamer said:
Good to see that like me you went with black paint, it looks very smart and with a silver clip just adds a bit of class
I have to admit pictures of your brakes were an influence
PawnSacrifice said:
Actually sort of doing the same thing at the moment, so it's been really good to be "working with" someone on this. Just, well, did you have to set the bar that high... damn you got those things clean! :roll:
Few things... how did you do the clips in the end? Did you start with new ones?
Where did you get the black paint?
Was all the cleaning done with the Dremel style tool wire wheel attachments?
Am now considering black again... it's one of those corner of your eye things; not as immediately apparent as black, but the details all add up.
I don't know if I set the bar high or just did things unnecessarily thoroughly. Don't clean the calipers in an enclosed space - everything in the garage is now covered in a layer of black dust! I painted the calipers with a Foliatec kit,
bought here. That listing is "New Old Stock" so bit dusty and labels peeling but did the paint did the trick. You mix a tin of paint with a tin of hardener - I think it's an epoxy based paint. You leave for 5 mins and it starts to go thick. You have time to do a coat, wait 15 minutes and then do the second. After about 30 minutes the paint cures so best to only mix how much you need. The brake cleaner aerosol didn't work so chasing up with seller - get some in if you get that pack. I only got it because Halfords didn't do black caliper paint - not sure if the extra cost is worth it over
this high temp enamel paint.
The clips were done with a coat of black caliper paint and then some chrome spray paint from BnQ. Nowhere near as good as real chrome clips but these would have been £16 for new clips and about £35 for someone to chrome plate them.
All cleaning was done with a power drill and the wire brushes I mentioned earlier. Definitely get Dremel ones too as they are great for all the corners and tricky areas. Get a couple of each size as they don't last too long,
this seems like a good deal on a decent power Dremel if you don't have one yet.
I like the red on CJs car as I think the sportier 108s get away with it. Was a tough choice between red and black but in the end I think they look good as black/chrome matches really well with freshly gel'd black tyres and chrome effect wheels.
cj10jeeper said:
So why aren't the axle stands under the jacking points as insurance? It may look like a toy and the jack will easily hold it, but if the ground sinks, seal on the jack bursts, it'll feel real heavy in you :thumbsdown: Worst case just put the wheels under the sills.
They are - just my choice of photos tricked you
The car was actually sat on stands with the jack just below as a safety net. I let it down a tiny bit to make sure the stands were taking all the weight and gave it a good shove before taking wheels off to make sure it was sturdy.
