MKZ4000 said:Do they not fit non M Z4’s (E85)then?
True-Blue said:MKZ4000 said:Do they not fit non M Z4’s (E85)then?
Genuine ones don’t as far as I can tell, my 224’s are 9j et30 and sit almost perfectly flush with the arches.
CSL’s are 9.5j Et 27... so would poke, not a fan of stretching tires personally
mr wilks said:They have been done before on Si Zs , a coupe owner in France has them on his car
If intending to buy its worth confirming if the fronts are M3 or CSL ( 8j or 8.5j :?) its no issue which ones RE fitment but does affect value slightly
True-Blue said:mr wilks said:They have been done before on Si Zs , a coupe owner in France has them on his car
Hi Mr Wilks, they are 8.5j fronts.... my car is not an Si it’s a 3.0i on the B12 Kit
Have RC337 stamped on them & RC338 I think?... has an invoice from a BMW main dealer apparently.
SiJar said:Mr Wilkes are your CSLs original and what size wheels and tyres are they? What size wheels width (OEM) CSL’s on a standard Z4M Coupe would you recommend?
Si
Si
mr wilks said:SiJar said:Mr Wilkes are your CSLs original and what size wheels and tyres are they? What size wheels width (OEM) CSL’s on a standard Z4M Coupe would you recommend?
Si
Mine are the CSL set up so 8.5j et 44 front with 235 35 19 & 9.5j et 27 rear with 255 35 19 ( some fit 265 30 19s) they will fit your car to perfection
Snoop D said:mr wilks said:SiJar said:Mr Wilkes are your CSLs original and what size wheels and tyres are they? What size wheels width (OEM) CSL’s on a standard Z4M Coupe would you recommend?
Si
Mr wilks the stance on your Z4 is just perfection![]()
What suspension are you running? (Eibach B12/H&R?) Looks pretty low...
