Hi all,
Quick heads up, cheapest I've seen a pair of these discs at £229.50. Was at £270 but knocked down this morning. These are the genuine BMW performance perforated discs that are a direct fit onto the 3.0si.
Expensive but they're almost 1.2kg lighter per corner than standard discs with a semi-floating aluminium hub and directional cooling vanes with perforations. Essentially the same design but as the M3/Z4M/CSL discs but shrunk down and designed to fit standard hubs.
Here you go:
https://www.ebay.co.uk/itm/BMW-Genuine-Brake-Disc-Set-Front-Left-Right-E46-E85-E86-3-Series-Z4/183493730301?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Only one pair left on this listing because I bought the other pair!
Discs are number two in this diagram:
http://www.realoem.com/bmw/enUS/showparts?id=BU52-EUR-04-2007-E85-BMW-Z4_30si&diagId=34_1284
Here you go:
