Gearbox/Diff Oil Change
craigdm
 Lytham St Annes, Lancashire
What is the service intervals on these two, seem to remember the gearbox might be 'sealed for life'???
My 3.0Si is now 8 years old and coming up to 95K miles, and I was hoping some new oil might ease the gear change a bit.
Easy DIY jobs, or expensive indy?
The diff and gear box oil are supposed to be life long!!
I changed mine last year and they where both in a right state. I would recommend doing or getting them done. It is a fairly easy DIY job you just need to get the car in the air to get underneath.
My car was 11 years old but 65k miles.
Make sure you remove the filler plugs first , nothing like draining the oil then finding out you can't fill it back up :cry:
Did mine at 19k miles and even at that mileage the old oil wasn't pretty when it came out so I'd hate to see it after 50 / 60k miles!
BMW have this thing about "filled for life" g/boxes and diffs. The bike is the same with the F/D (final drive) being quoted as filled for life on the earlier models. The oil capacity on the R1200R F/D is 180ml - which is a miniscule amount of oil - so how they came to the conclusion that it would cope for 10s of 1000s of miles is beyond me. As it happened they modified the F/D housing on later models to include a drain plug and a filler after numerous warranty claims within the first 12 months. Thankfully mine has the drain / filler holes. Later they also fitted a F/D casing breather - which should have been included at the initial design stage. I've fitted my own now and the oil gets changed in the F/D every 1000 miles, it takes about 15 mins.
