Vanne said:You thought about doing it yourself? It's quite easy and you'll learn a bit about the car which is always helpful.![]()
It should come with very detailed instructions, and if anything like ESS, it's a pretty easy job. The hardest part was running the intercooler lines, which I am not sure your kit has?
Mee too . Are you looking to buy direct from ess in USA or through a UK company , I see AReeve Performance do a supply and fitJoycey said:I struggle to read these threads, I'm so close to pulling the trigger ordering myself an ESS kit.
Look forward to hearing your results.
Barrett.d said:Mee too . Are you looking to buy direct from ess in USA or through a UK company , I see AReeve Performance do a supply and fitJoycey said:I struggle to read these threads, I'm so close to pulling the trigger ordering myself an ESS kit.
If it's anything like the size of the ASA/G-Power/Infinitas kit, then you are not getting that on a plane without paying for a pallet in the holdJoycey said:What ever option is cheaper, I often fly to the states so can pick it up personally if needed. I explored the ESS kit a few years ago with the Gen1 kit where they locked out the valvetronic, Glad to see with the gen 3 all the niggles have been sorted.
I see Mstyle in London supply and fit Gpower kits , might be worth a shoutgr3mlin said:Looking for some recommendations for garages to fit G Power supercharger kit on my Z4M - can anyone recommend somewhere?
Barrett.d said:Apart from rod bearings and a general service , what other work is needed before installing a supercharger. Does the clutch need uprating or is oem up to the job ? Also drive shafts , diff . Or any other bits that need uprating apart from brakes and suspension? Ess 525 needs to happen in the summer , just need to know how much more I need to spend on other bits
Thanks for the replyTomK said:Barrett.d said:Apart from rod bearings and a general service , what other work is needed before installing a supercharger. Does the clutch need uprating or is oem up to the job ? Also drive shafts , diff . Or any other bits that need uprating apart from brakes and suspension? Ess 525 needs to happen in the summer , just need to know how much more I need to spend on other bits
I'm always surprised the gearbox gets no mention in these s/c conversions given the ZF S6-37 trans we have is rated to a max of 273lbf-ft, and whilst it is fitted to a 320d or 520d it was not fitted to any 30d variants which comftably exceed this torque limit as would a blown s54 :?
Barrett.d said:Thanks for the reply![]()
Was wondering what I could "get away with " . Is the gearbox something that needs doing prior to install or something that can be left until the old one fails ? What are the uptions regarding uprating the gearbox ? Thanks
