Gaptech group buy!
Ok, im interested. Want me to add to list now or when paid? Won't be next couple of days as away with work but interested.
Just paid up! :thumbsup:
Thanks mate for organising this - awesome stuff!
1. Hopz121 (Ash) - Gaptech RCH+ ...............Paid
2. Pazaz29 (Col) - Gaptech RCH+...............Paid
3. Stuartt (Stu) - Gaptech RCH+.................Paid
4. Harry911 (H) - Gaptech RCH+
5. Mike46 (Mike) - Gaptech RCH+...............Paid
6. Moheddine (Moheddine!) RCH+
7. Jordnm88 (Jordan) - Gaptech RCH+
8.. kayjay0_7 (Kelvin) - Gaptech RCH+ ...............Paid
9. GingerNinja - (Martin) - Gaptech RCH+ ...............Paid
10. Dudda (Tom) - Gaptech RCH+ ...............Paid
11. Stu Boy (Stu) - Gaptech RCH+ ...............Paid
12. Shady Ady (Ady) - Gaptech RCH +.........Paid
13. Fullmonty (Bav) - Gaptech RCH+.........Paid
14. tgarvie (Tom) - Gaptech RCH+
15. Allymally (Malc) - Gaptech RCH+ ...............Paid
16. Chii (Ryan) - Gaptech RCH+ ...............Paid
17. Thuzbuz (Charlie) - Gaptech RCH+ ...........Paid
18. Sean_flitton (Sean) - Gaptech RCH+
19. 99ron (Gary) - Gaptech RCH+ ...........Paid
20. Midhurstman (Barry) Gaptech RCH+ ...........Paid
21. S3NYR( Alex) Gaptech RCH+
22. bony_13 (Ian) Gaptech RCH+
23. Barralee (Lee) Gaptech RCH+
24. Jamesfawcett (James) Gaptech RCH+ ...........Paid
25. Gofaster90 (Dave) Gaptech RCH+.........Paid
26. Zoomer (Daz) Gaptech RCH+ ...............Paid
27. JINGLE (Jamie) Gaptech RCH+ ...........Paid
28. sasker (Stuart) Gaptech RCH+ ...........Paid
29. confused (Phil) Gaptech RCH+ ...........Paid
30. Pdv415uk Gaptech RCH+ ...........Paid
hopz121 said:
Great to see so many people getting on this, what's the best connection for fitting? I have heard the standard ones aren't great! I don't really want to solder it if possible
If you don't want to use the scotch locks supplied the only other way is to solder it, which is the only way imo.
4. Harry911 (H) - Gaptech RCH+.................Paid
23. Barralee (Lee) Gaptech RCH+,................Paid
I'll be using proper pins and connectors, the same as all OEM BMW connections. :thumbsup: Makes it easier if it ever needs removing.
You got a link Mike?
I like the sound of that?
I haven't im afraid, as I simply have them at work.
Something similar to KayJay's post above would do, but it doesnt need to be waterproof. The only problem with that is that you probably havent got the correct tool to crimp them.
In which case something like this may be more suitable: http://www.halfords.com/motoring/garage-equipment/tool-kits/halfords-wire-crimping-kit
kayjay0_7 said:
I've ordered a 5pin connector like this
http://m.ebay.co.uk/itm/321634982523?nav=SEARCH
Thanks for the link, is it 5 pins that are required then for the Gaptech?
31. Boyee Gaptech RCH+
You won't need them connectors, there is not a lot of room behind the console. Soldering is the only way to insure good connections! :D
Don't use the scotch blocks provided or you be doing the install again due to broken wires or loose connections :?
https://www.bimmerfest.com/forums/attachment.php?attachmentid=282927&d=1309026407
21. S3NYR( Alex) Gaptech RCH+ ....................Paid
You can use crimped bullet connectors.
You can use what method you want but personally I didn't want to cut my loom!
I would never use the supplied scotch blocks on anything!!
I'm an electrical engineer and these scotch block connectors should be wiped off the face of the earth IMO they are a cause of so many electrical issues.
Soldering is the best way to connect retrofit wires in the automotive sector...
I don't want to cut my loom either, can you solder on the wires without cutting off the loom then?
Is there a how too anywhere?
Your have to slice the wire loom with a Stanley knife, wrap the new wire around the loom wire you just exposed, then solder & tape over the joint!
Before you do that disconnect the battery, I didn't but I've done it more times than I can count!
