Well in my search for car start problem i pulled the fuse tray, i yanked it out and found out how it works.
So metal bracket pivot point should allow it to drop after removing the screw.
Note next to bracket unused LH drive access for cable wiring, i blocked it with some insulation stuff.
I see it probably needs the left speaker cover trim to be removed.
Then the tray is supposed to slide out.
Still difficult to get at some fuses unless tray is detached from arm.
I had to remove bracket and squeeze it to make it fit the arm.
