I fitted non-M lollipops during a refresh and did 10k miles before replacing them with ///M items. I noticed no difference, albeit was already running higher than OEM caster via adjustable top mounts. Maybe slightly greater steering self-centre, but could quite likely be placebo effect.jontZ4M said:Thanks. Do you think using the centered bushes on a Z4M will be a problem? Not sure how critical caster is.
jontZ4M said:Hey guys - just an update. The refurb is going well, if not a little slow.
Today I was installing all new bushes and ball joints. There is just one that I can't get in all the way. It's 33172282484 which is the single bush in the rear subframe that accepts the diff. I can't find a way of getting enough pressure on the bush to get it all the way it. I'm using a normal bush installer, BUT critically I can't really use it properly as there is nowhere to mount the opposing part of the tool because of the subframe's weird geometry in this area. Using the angle iron in pic just results in angle iron bending. Reinforcing angle iron results in it still bending.
EDIT - that's a pic of removing old bush BTW(forgot to remove before power coat). New one going in from left to right.
john-e89 said:Have you wiped a film of lithium or silicone grease round the bush and subframe jont….? If not I suggest you do, it’ll go in then for sure.![]()
lucasxdiniz said:I replaced this bush during some refurb'ing I did last year. I did not have any issues putting it in, but I did get something turned specifically for this, and I left the bush in my -18°C freezer overnight and pressed from diff side to bolt side.
You can borrow my tool if you wish. Some pictures here.
jontZ4M said:Thanks Lucas. I don't have freezer at workshop but I noted you can buy instant freeze spray. I know metal can become delicate at low temps so was just a little wary about breaking any frozen parts.
I looked through your thread, you are putting my level of detail to shame lols. Well done on yours. I can't see the tool you are talk about? Am I blind?
lucasxdiniz said:don't see it that way, I wish I had been able to remove the sub-frame and done it properly like you. It's this one, nothing fan
ed80 said:Thanks guys, I managed to get the four bolts to the manifold undone with only the regular amount of swearing. Picked up an O2 socket from halfords as well to hopefully make the sensors come out easier.
I guess the last step is to remove the exhaust mounts at the rear and use a jack to lower the whole thing until the other connectors can be removed.
Have given the rear exhaust mounting studs another soak in WD40, they are in a right state, hopefully nothing snaps.
ed80 said:Have given the rear exhaust mounting studs another soak in WD40, they are in a right state, hopefully nothing snaps.
ed80 said:The centre section needs to come out, and the bolts that connect it to the cats have totally disintegrated. I can probably grind these out without too much difficulty, but the top bolts are totally inaccessible. I think that even with bolts in good condition these would be tricky, is there any way to get access to them more easily?
