Fuel returnline 2003 z4
Is anyone build returnline and delete oem fpr and modify m50b25nv intake/fuelrail with fpr?
I have some issues with my turbo setting with fuel pressure. Fuel pressure doesn't work with vacuum guided and i think problem is that fpr witcis in the tank.
I fitted an Infinitas s/c early last year and the first part of the install is to replace the fuel filter/pressure regulator in the tank with a higher pressure one supplied in the kit. The standard one is 3.5bar, the higher pressure is 5bar if I remember correctly. I've never had an issue with it. Is this what you mean ? :thumbsup:
Infinitas Superchargers are in Gachenbach near Munich, Germany :thumbsup: https://infinitas-automotive.com/en/supercharger/
Yes, engine rebuild with forcet piston, h-profil rods etc. But fuel problem, but i think that oem fpr cause the issue, need to plug or something. Build return line and change fuel rail m50 with m50 fpr vacuum/boost guided
