Fuel Pressure Measurement
Mangozac
 QLD, Australia
Just a quick one guys: does anybody know where to go about measuring fuel pressure on the Z4M? On N52s there is a Schrader valve on the fuel rail. On E46 M3 the valve is next to the fuel filter under the car but on the Z4M the fuel filter is inside the fuel tank.
Anybody know where it is?
Can't you just decouple the metal fuel feed line at the beginning of the fuel rail and measure it there or on the fuelline that goes into the metal fuel feed line (that has an ordinairy fuel line coupling).
Or directly on an injectorcoupling?
Just decide what's easiest regarding the adapters that come with your fuel gauge kit.
Not so easily on the S54 - the line enters the rail underneath between two injectors and isn't accessible without a lot of disassembly due to the idle air bypass rails and other items in the vicinity.
I'm sure the fuel line can be pulled somewhere but it's just a pain and much more preferable to use an actual fuel pressure measurement point ;)
