stlymch said:I've heard its a git... why do you want it off?
Ewazix said:I replaced the painted outer on mine when it got dented at a fuel stop![]()
Very easy to remove the outer cover from the hinge by sliding plastic tabs on the rear IIRC then slide the cover off. No need to force anything but the tabs are not obvious at first.
Beedub said:Just wondering has anyone removed the fuel filler door, if so do you have any tips to remove it, I'm not local to the car at the moment so I'm unable to check if their is a pin or whatever holding it on. cheers in advance.
Citation 650 said:Beedub said:Just wondering has anyone removed the fuel filler door, if so do you have any tips to remove it, I'm not local to the car at the moment so I'm unable to check if their is a pin or whatever holding it on. cheers in advance.
It pretty easy. Check the last post on this link:
http://www.z4-forum.com/forum/viewtopic.php?t=58156
