talking of whichDaffy said:50ish mph slipstreaming behind a truck I can get 45-49 MPG out of the old 330ci.
It's the worlds most boring journey ever though......no speed and the arse end of a truck as a view for the entire trip :-(
I mostly agree, but you don't have to sit behind a truck, you can sit in front of them.Kiowan said:it's dangerous to do low speed, especially in a small car and moreso in poor visibility or bad weather where if you are doing similar speeds to trucks you are much less likely to be seen or end up sitting in a blind spot
cj10jeeper said:I believe 56 is the so called magic number for almost any car.
A speed that allows cars to hold high gears without labouring before the effect so wind resistance begin to climb significantly.
65 will certainly be too high, but may not be significantly worse on an aerodynamic car like the Zed
benlumley said:Anyone any thoughts on with the roof up/down?
Mine seems to be significantly worse with roof down - but judging by the impact windows had in my old car, that seems vaguely normal?
aquazi said:benlumley said:Anyone any thoughts on with the roof up/down?
In the average speed bit on the southbound M1 (think its around 10miles long) at 50 mph roof up my ODBC said 46mpg. On the way back up with the roof down (windows up seat heaters on first setting) i got 39 mpg... but then it might be more uphill.... but my car would have been lighter with less petrol!
The traffic conditions were also different.
nicko said:over my 10.5 mile dual carriageway test track, with cruise control on all the way, air-con off, fuel level ~ 3/8
Northbound
50mph - 54.3mpg
55mph - 52.3mpg
60mph - 51.3mpg
65mph - 47.8mpg
Southbound
55mph - 44.8mpg
60mph - 44.1mpg
65mph - 40.3mpg
70mph - 37.6mpg
OT, sorry, but FYI, the US uses an average of 2 different octane determination methods, RON and MON. MON is usually 8-10 below the RON method used in the rest of the world, so a US 91 works out to 95 or 96 RON. We still have crap fuel, too much sulphur, but it's not in the octane rating.Kiowan said:US 'premium' fuel is a whopping 91.
