Fuel cap
flybobbie
Elite
 Stourbridge
It finally happened, the fuel cap cord broke.
But by chance a piece of telephone cable outer insulator was just the right diameter for the rubber to be glued in to.
I've never fully understood why it's there in the first place!
There is a locator for the central stud of the cap in the top of the flap where you can place the cap while you are re-fuelling, so why do you need a "cord" to retain it?
IMHO ;)
IMHO ;)
Because in general people are idiots put them on their roof, boot, petrol pump, etc. and drive off
IMHO ;)
Hence why you have the locator in the top of the flap, otherwise you have the cap potentially banging into the same spot on your Z's body every time you "let it go"
Yes indeed, people are idiots!! 🤣 :thumbsup:
flybobbie said:
The cord stops you dropping it on the floor and we just know it would roll under the car!
Mine Broke a while ago, nothing more embarrassing than trying to crawl under the car at the petrol station with everyone looking ... 🤣
IMHO ;)
There is? :-o
Another learning day - so obvious when you know :D
IMHO ;)
There is? :-o
As attached.....
Hi
You can get replacement cords off flee bay I have replaced the old ones on my E85 and E92 easy to replace and work like the original units
Regards
Allan
Allan280 said:
Hi
Regards
Allan
I have also used the replacements with good results :thumbsup:
My fixing method :-
A small length of Heat Shrink Tube with the inside coated in adhesive ( i used epoxy) assemble and heat.
