Crazy Harry said:You should be able to watch the action of the plastic pin with the fuel flap open - click the key fob a few times. I changed mine at 34K miles as the surround (nothing more than a hollow guide tube) was badly worn. Think a new one was £5 or £6 from an ebay seller. Very quick to change and a dab of vaseline or alike will help the action.
Ilogik said:Crazy Harry said:You should be able to watch the action of the plastic pin with the fuel flap open - click the key fob a few times. I changed mine at 34K miles as the surround (nothing more than a hollow guide tube) was badly worn. Think a new one was £5 or £6 from an ebay seller. Very quick to change and a dab of vaseline or alike will help the action.
Old thread revival anyone got a how to?
Ilogik said:Hey thanks for reply, I can only find this atm?
https://www.ebay.co.uk/itm/314002083852?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=Ti5u7ufhSSu&sssrc=2349624&ssuid=FN7nC8m1SQ6&var=&widget_ver=artemis&media=COPY
What did you search for a new rod and any tips on getting it in.
Ah ha. So we are assuming the pin has snapped off, but you're thinking it's still there but not lined up?Crazy Harry said:Ilogik said:Hey thanks for reply, I can only find this atm?
No. If I understand your post you only need this:
https://www.ebay.co.uk/itm/264927154986?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749392&toolid=20006&_trkparms=ispr%3D1&amdata=enc%3A1nIfnlml5TGWBxKd5cr1Diw96
The fitment list includes E85 and E86 but you could always message and check with the seller.
enuff_zed said:Ah ha. So we are assuming the pin has snapped off, but you're thinking it's still there but not lined up?Crazy Harry said:Ilogik said:Hey thanks for reply, I can only find this atm?
That was the case with mine - which I where I came in when my old comment was quoted. Haven't been here for months (its another long story) but happened to log in and find the notification.
Pull the guide out and you should be able to see the plunger; fish it through the hole then with the fuel flap wide open lock and unlock the car the plunger should move in and out of the hole. If it does slip the guide over the plunger and push home into the hole. Five min job!
PS glad to see you; Jock; Jingle et al are all OK!
We're all good thanks.Crazy Harry said:PS glad to see you; Jock; Jingle et al are all OK!
Crazy Harry said:enuff_zed said:Ah ha. So we are assuming the pin has snapped off, but you're thinking it's still there but not lined up?Crazy Harry said:No. If I understand your post you only need this:
hey sadly I'm a bit far away, over in Birmingham. Thank you for the offer.enuff_zed said:[ref]Ilogik[/ref], where are you? If close to me you can come and take the one out of my breaker. Learn how to access it and get a replacement.
Ah well, let me know if you need it though.Ilogik said:hey sadly I'm a bit far away, over in Birmingham. Thank you for the offer.enuff_zed said:[ref]Ilogik[/ref], where are you? If close to me you can come and take the one out of my breaker. Learn how to access it and get a replacement.
