Fuel Additive recommendations please
TOMGREEN413
 Somewhere in deep darkest Wales
Hi folks
Here in Wales the E5 prices and availability are making me think about using a good quality fuel additive to maintain the fuel ,ines , injectors etc. I was curious to hear from anyone who uses an additive and which might be best for the 20i ENGINE. Thank you in advance.
This comes up a lot, and the first thing is that E10 is fine in your car — anything BMW built after 2011 is compatible, and the fuel line and seal worries belong to classics rather than an N20. UK petrol has to meet a tight standard whoever sells it, so you're not buying dangerous fuel at the cheap pump. What does vary between brands is the detergent package, and there the supers are genuinely different — Esso's Supreme+ 99 carries double the detergent of their regular grade. Worth knowing too that Supreme+ 99 is ethanol-free across much of the UK despite the E5 label on the pump, though the published exceptions have included North Wales, so check where you are before making a special trip.
The bit to be realistic about is what any of it can reach. Your engine is direct injection, so fuel sprays straight into the cylinder and never washes over the intake valves — which is exactly why carbon collects on the back of them on these engines. Nothing in the tank gets there, bottled additive or premium fuel alike. Esso's own cleaning claims are footnoted as measured on port-injected engines, which tells you plenty. Detergents will keep injector tips and the combustion chamber clean, which is worth having, and a stabiliser earns its keep if the car sits over winter — but nothing you pour in will deal with intake carbon on an N20.
Happy to go into more detail if that helps.
Hi folks
I started looking into fuel additives a while ago. I gave up as it is so complicated.
Not according to BMW UK. E10 is fine for ALL BMWs and 95 octane is fine for all built after 1998 no matter what.
https://www.bmw.co.uk/uk/s/article/Is-my-car-compatible-with-E10-petrol-OvmHu?language=en_GB
Well they might all be capable of runing on 95 RON, but in the handbook for my 2005 330i, 2006 3.0Si and 2006 M BMW recommended using at least 98 RON "whenever possible" so that's what they get - whenever possible!
I'm sure B21 is right about the later models being fine on E10 though.
Most of Peter's post was interesting and made sense. But the two first lines were not correct. Unless he knows more than BMW about their cars. He would probably say he does!
Being factually incorrect is OK if the poster uses the words 'suggest' or 'opinion', or similar. But Peter doesn't work like that. Being the self-appointed guru on all things E89 (and it is self-appointed) he states things as fact.
People who don't know that some of what he posts (not all) is bollox could easily think that everything he says is cold, hard fact and act on it.
Behaving like you know everything is very different to actually knowing everything.
I dread to think how much of his 'book' is filled with incorrect 'facts'.
Hi folks
For those of us not local, what is the current cost of each?
I'm looking at $4.20/Gallon USD (82p/litre) for Costco 93 octane, which is probably closest to 99 RON E5, but our tax structure is different
Since the OP wanted to know about HIS car and didn’t want a life and times of all BMWs I just restricted the discussion to later, direct injection turbo BMWs… things like washing the inlet ports with fuel don’t exist on DI cars, but high quality fuel contaminating the oil less is true.
So the answer varies by model / year …the turbo versions are quite partial to ethanol ..the fuel treatment if you insist varies between DI and PI.
Better quality oils that are thermally and chemically more stable would be a logical focus.
Wow, thanks everyone for taking the time and effort to post the above information, much appreciated. Looks like the wife can stick to E10 with the occasional E5 treat for the e89. This information has saved me many £££'s......... : ) So many helpful legends on this forum x
Here in the States the highest octane rating we can get in my area is 93 octane. Due to the Iran situation the .gov has authorized a higher ethanol concentration in our fuel to keep costs down. My 2010 Z4 runs like complete garbage with this new concentration. Luckily there is a fuel station nearby by that sells 93 octane non ethanol fuel, but it is pricier at $5.15/gallon last fuel up. My car runs so much better on this fuel.
As far as additives, I was always informed that anything containing PEA is good to go.
Here is a good video on the topic
Porsche Fuel Additives Video
Which your idiot president started and we are paying through the nose for. Fuel has increased by over 20% at the pumps here in the UK and it wasn't exactly cheap before!
Prices are extortionate at UK pumps primarily because of UK taxes. Slightly off the original topic, but I'll expand on my comment, to offset some of the "Trump derangement syndrome" which has obviously reached the UK.
I attach 2 pics of my local petrol station in Japan, taken within the last hour. The forecourt price for premium is 173 yen, the princely sum of 80 pence per litre. That is member card holder price, the pump price (yellow column) is 175 yen per litre, a ridiculous 81 pence per litre. This is sold as high octane, 96 - 100 RON. I just put some regular in my wife's car @ 164 yen, 76 pence per litre.
Japan has virtually ZERO oil resources of it's own, this comes via the very same Strait of Hormuz that the UK uses.
In the 25 years since I left the UK, I have seen consistent bull manure from the main stream media and successive governments blaming every failure on climate change, Trump, the wrong kind of weather or anything they can think of to distract from their ineptitude.
If Japan can do it, I'm sure the once Great Britain can do it too.
PXL_20260813_224932897 (Small) (Small).jpgPXL_20260813_223553155 (Small) (Small).jpg
Road tax is a swizz in the UK.
My 23i over £400 a year 26mpg knocking around..
I often look at SLK diesels, £25 road tax, 40-70mpg, same hp as 23i, auto.
But once i saw a chap in New york his DB9 was like $100 a month insurance.
Cost me £120 year fully comp. in the UK, not London, when i checked same car/year.
Would you really want to listen to a canal-boat soundtrack when you had the roof down just to save on Road Tax and fuel?
There is no SLK I'd want because manual ones are like hens' teeth, and any with a bit of grunt all come saddled with an Autobox. :(
Slightly back on topic what fuel do the petrol SLKs need?
There's always one smart-arse. :poke:
What Octane rating, E10 or E5 for the sake of clarity.
🤷‍♂️ I’m merely answering your question Mr Tidy, there’s no need to be snotty about it….😭
It’s an SLK….not a Veyron sire….it’ll run on Mazola chip oil and paraffin if needed…..🫵😈
(Please can you tell me how to get the pointy stick thingy….🙏🙏 I promise to save it purely for Pondy and not you….even when you’re being soppy as a sack….😬)
