A
Anonymous
Guest
Hi,
Finally plucked up the courage to empty my shed, found loads of bits I'm putting up for grabs on the forum before I put them on eBay.
All parts located near Gotham in Nottinghamshire, about 10 mins drive from Junction 24 of M1. Collection welcome on all parts.
1) Hertz ESK 163L 3-way component speaker system. It outputs 250W and has speakers that replace the tweeter in the door, the speaker in the footwell and adds a speaker to the door. This is brand new as you can see in the pictures, I did test fit a speaker in the door just to check it was the right size. There is a how-to in the forum audio section that uses these speakers. £120 + P&P SOLD
2) Massive Audio Nano Block NX4 Amplifier. It outputs 4x100W rms but I was going to bridge it(2 x 200W rms) to run the front speakers above. It is the smallest amp I've come across with enough power output to make things loud enough for a roadster
It was part of a system installed in a Lambo that was removed to put it back to standard. I did test it when I bought it and it powered up and sound comes out. Dimensions: 10"L x 5-1/2"W x 2-1/8"H.
I was going to install this behind the dash under the carpet on the passenger side, but it is small enough to slip under one of the seats. £80 + P&P Sold
3) Silent Coat vibrodamping 20 sheets bulk pack. I was going to line the inside of the doors with this stuff while I was installing the speakers. It will stop the doors vibrating when the speakers are installed. It will also make your doors sound solid when you close them. Brand new never opened. £20 + P&P Sold
4) Butyl tape to reseal the waterproof membrane on the door once the speakers are installed £5 + P&P Sold
5) Fli Line Level Converter. This will convert the standard speaker wiring into pre-outs for wiring up the amplifier £5 + P&P
6) Centre console in grey, long piece that goes from passenger side around the CD player upto the steering wheel.
It has a broken clip on the back and a scratch near the CD player hole, I was going to use it as a template for a nexus 7 holder but never got around to it. £10 + P&P
7) Pair of windscreen wiper blades, new never used. Bought them to replace mine but got some new ones for free with new window. £10 + P&P
8 ) LED License Plate Lights. £15 + P&P Sold
9) Wing mirror cover - un painted, it was with a bunch of parts I bought to do some repairs. £5 + P&P
10) Full set of 18" Bridgestone Potenza RE050A* runflat tyres removed from my 108's after covering about 11000 miles. One of the front tyres has a knick in the side wall but didn't cause any problems through 2 MOTs. Might be useful for a few thousand miles. Fronts: 225/40 R18 88W 5mm tread. Rears: 255/35 R18 90W 4mm tread. £100, collection only due to size.
11) Set of 4 BBS 108 Alloy wheels in need of refurbishment. They were taken to be straightened and then I started stripping them down but never got finished off due to back problems. One of the front stars has some drill damage around and inside the hole where a bolt had to be drilled out, could be filled/repaired. Couple of bolts missing, the rest are there and seem reasonable. £125, collection only due to size. Sold
12) Passenger Rear Arch in Titan Silver with clips. Has a small? graze in the metal but not misshapen along shut lines so could be filled and repaired. The plastic clips are undamaged. Might be of use for a project? Free to forum members, collection only due to size.
13) Passenger Door in Titan Silver no furniture. Has a small ripple and couple scratches inline with the wing mirror, tried to highlight it in picture but its not obvious. £50, collection only due to size.
Thanks for looking, some pictures below. PM me with interest, I'll answer as fast as I can but please bear in mind I do work during the day and sleep during the night. Sensible offers welcome, will combine postage on multiple items.
