Front valance scuffs
Clobber said:
Z4 COUPSTER said:
Any1else said:
Cheers. Would like to see it - especially at the ends.
Here ya go.
You've done a nice job with that tape! Is it difficult to get a nice finish?
Tbh I was lucky as I have use of a ramp in work. Then out some extra self tappers in and done.
And if you clean the shite out of the underside it sticks very well.
D
aquarianone said:
How is that secured on, something stronger than sticky tape I'm guessing?
Tape to line up and secure, then self tapper screws. Had on the roadster for over 2 years and it's not fallen off.
It's cheap and easy ti fit, use and replace.
D
Clobber said:
Good advice, what glue did you use?
I just used some Gorilla Glue - but if you can do it I would try the method mentioned above by Z4 Coupster...much more robust.
Any1else said:
Thanks Z4 Coupster. Ordered some of the tape and will give it a go. Just hope I can get it on as straight as yours.
offer it up before fitting and cut ends when on car. Then it's easy.
D
Clobber said:
Ordered too... hopefully I won't bodge this!
just take your time get car as hi as possible and make sure all is clean. Once happy peel tape and fix as you go, doing around 2 inches at a time . Perl more tape etc. Then fix with small self tappers and trim ends with a sharp knife.
Job done.
D
Job done.
D
Did you use the self tappers that came with it? If so, where did you put them cos they are silver (odd) and would be really visible.
Any1else said:
Job done.
D
where the tape part sits under valance. So under the splitter. They will not be visable. And I used some extras.
D
Z4 COUPSTER said:
Any1else said:
Job done.
D
D
Mmmm. I have a 2003 and the bumper is different from yours and I can’t tell even on yours where the screws would go and not be seen.
Any1else said:
D
WP_20180909_14_32_29_Pro.jpgWP_20180909_14_32_37_Pro.jpgWP_20180909_14_33_16_Pro (2).jpg
Underneath behind splitter into valance on part that has tape.
Hope this helps best I could do.
D
Thanks for getting the pictures. The strip that I got seems to be different from yours. See attached. It will have to be face fixed and if I want to use screws they will be visible. Some black paint might be required but I can try and use the tape first.
it's identical bud. The tape bit goes on top...under valence....the rest sits down/out. The small lip goes on bottom and faces in..
it's identical. Tape goes under valance. Then screws go in that. The small lip is "under" see pics of profile
Ah, I see what you did there. I need to fix mine to the face of the valance to hide the scuffs on it rather than to the underside.
Thanks for the advice/pictures though.
