Jonny essex said:Well my tyres say on the front 235 ET35 19 :?Bing said:40 isn't the ET Jonny, it's the tyre profile... But as you say, shouldn't be an issue if it's not lowered.
My old one had spacers, and when it was lowered they tried it without spacers with the result that the wheels rubbed the inside of the arch on full lock. They solved it by putting the spacers back on.
Of course they then rubbed on the outside of the arches :roll:
Maybe the wheel arch liner is loose ? Bolts can loosen and fall out over time.
chris6 said:bing said:Enthusiastic driving can give rubbing even on stock springs and wheels - there is some on the outside of my arch cover behind the wing/bumper join on my current car, and it's not been tampered with at all.
That doesn't sound right . If car is as left factory can't see it being built like that. Do other M owners with standard set up get this problem?
fixit man said:It looks like your inner wheel arch is not fitted correctly, I think it should be on the front side of your wing ....where the plastic plugs go in, they should go through the wing angle then onto the inner wheel arch, not the way it is now... wheel arch then the wing !
That should give you the clearance you need !
ba3bas said:fixit man said:It looks like your inner wheel arch is not fitted correctly, I think it should be on the front side of your wing ....where the plastic plugs go in, they should go through the wing angle then onto the inner wheel arch, not the way it is now... wheel arch then the wing !
Thats NOT how it should be. The picture is correct.
What you're saying is what most of us do to avoid rubbing pal and an easy cure without taking the wheel off.
The rubbing marks are symptomatic of your car being lowered so if you haven't check the springs/shocks.
Use a heat gun too to flex the bits touching rubber and push in
