Front tires rapidly wear outside edges.
Heckfire
New member
As the title says. My front tires are disintegrating so fast ol boy at the tire shop can't get the lugs tightened before I need more. The outside mostly. The handling is kinda f"d as well. Any part of the road that is uneven either pushes or pulls the car. And the ride seems rougher than I would imagine it to be. Any ideas are greatly appreciated. I don't really know anything about the car and have only had it a week. It's a 2004 z4 that's all I know about it. TIA
Id start by getting the alignment sorted, sounds like toe angles are wrong.
Then check tyre pressures, and that you dont have run flat tyres.
The ride is quite firm, what size wheels are you running?
I'd check condition of all the front suspension joints and change any knackered ones before getting an alignment done.
