TheDan said:I went for the following:
- Brembo 4 pot calipers from a Megane 3 RS
- Adapter brackets to fit these calipers to the Z4
- MTEC grooved vented coated discs (325mm)
- HEL braided brake lines
- Carbotech XP8 pads
brillomaster said:its probably worth asking, what are you trying to achieve? are you actually after better braking performance (say for track work) or just something that looks better behind the wheel spokes?
JamesClements said:Where did you get the brackets just out of interest? - Been considering something like this for mine. I have upgraded discs and pads at the moment OP which is definitely an improvement over stock
TheDan said:JamesClements said:Where did you get the brackets just out of interest? - Been considering something like this for mine. I have upgraded discs and pads at the moment OP which is definitely an improvement over stock
I actually got the calipers, brackets and bolts from this Polish company and is the same system Liam22 currently uses.
https://k-system.pro/en/product/bmw...t-conversion-kit-megane-3-rs-calipers-325x25/
If I'd known someone who works in a machine shop or a decent machine shop near me I'd have bought the calipers separately, measured everything up, CADed up a design for the brackets and got them fabricated. But this was only slightly more expensive.
Ebt said:Hi thank you the Dan I will looking to do the same as you the 3rd option where did you get the bracket for the calipers mate
TheDan said:Here is my system at the fronts:
kis said:I notice on the site you've referenced, that the cost Megane and Clio callipers are the same. Did you take a look into the pros and cons between the two? I'd imagine the Megane pads will be more expensive than the Clio? But do they offer better performance? i.e. why did you go for the Megane's in the end?
Do you the user name of the ownerjohn-e89 said:There is also Vagbremtechinic in the UK, the owner is a member here.![]()
Ebt said:Do you the user name of the ownerjohn-e89 said:There is also Vagbremtechinic in the UK, the owner is a member here.![]()
Jakg said:
kis said:I like the idea of the Megane’s as there’s no need for a spacer. All other set ups need some sort of spacer afaik. @TheDan you’re not using a spacer are you?!
