Front brake callipers carrier bolts
birdy_z4
 Warwickshire
Hi All
So replacing my front brake discs
Anyone know what the bolt size is?
Not 19mm
Is it 18mm ??
Tried all the sockets and spanner’s so unusual size :-(
They are a standard metric size, 18mm :thumbsup:
And they will (or should) be really tight.
birdy_z4 said:
Thanks all cheers for the advice
There is a trick for popping the disc off the hub if you need it. It involves an M8 bolt and three nuts.
Thanks all 18mm socket ordered
Managed to get the old discs off without removing the carrier but new ones won’t go in without removing it
I have to say I'm surprised there's no 18mm in a standard socket set?
bg1 said:
Go on - tell us!
Take an M8 bolt, any length will do. Select three nuts.
Lay them all neatly in a tray.
Take a large rubber mallet and knock the disc off. :D
That's one way, yes! :D
There is a youtube video showing how but I can't find it :roll:
You put the bolt(s) through the hole(s) of the calliper carrier against the inside of the disc with nuts to hold it in position. Then using the nuts wind the bolt into the disc face. It works like a reverse puller, so a pusher in effect.
It's hard to explain but is very simple and works really well. :thumbsup:
I suspect you'd need to rotate the disc a couple of times or it may twist and get stuck?
TBF though, usually once you break the initial resistance it comes away easily.
I did the above with all four of mine purely as I was concerned with damaging the centre hub by smacking the very edge of the discs with a hammer. The bolt method puts the pressure nearer the centre of the disc and they 'pop' off. Hardest thing was finding bolts long enough (need at least 70mm IIRC).
I also have an irrational fear of the car falling off the trolley jack if I belt anything too hard :o
I would say that was completely rational. I feel the same.
I would have a perfectly rational fear of working with you if you leave it just on a trolley jack. :poke: :wink:
