FREE Z4 interior bits
do you still have the strut braces (he bits that go from the middle of engine bay to the suspension) ??
Are the interior grab handle covers still available?
I'm looking for a set, doesnt matter if they're scratched, just preferably with tabs in place.
Hey dude, weird one but do you have the plastic panel that sits right at the bottom of the centre console above the switches for the roof/seats/DTC etc., pretty much unvisible unless you look for it. This bit:
IMG_1111 by TECribb, on Flickr
I drilled mine about 8 times before I got the whole for the AUX in the right place :roll:
Ta!
Ta!
Think I have it....£5.00 delivered ok?
Got an approximate cost for roll bar covers delivered? Mine are a little scratched!
Also, the little plastic silver covers that go on the door handles, mine have broken clips and fall off non stop :(
Oops, just given them away to another member.....doh.
Regarding the roll bar covers, I managed to snap a few fixing tabs off trying to remove them so maybe you would be better off buying new, as I cant see any way to remove them without breaking some of the tabs.
Sorry dude
Sorry dude
:cry:
No worries
:cry: :cry: :cry:
Hi foxy-stoat
I'm interested in the plastic trim, directly below the handbrake lever.
Not just the small rectangular removable piece, but the two bits either side.
I don't need the plastic around the gear level.
How much posted please?
Also, do you have the ashtray black insert?
Is there any chance I could get the bonnet alarm sensor? I know this part is only like £8 from a dealer anyway. But I have been seeing some problems with my alarm going off randomly and it's most likely this part as the alarm does not go off when disconnected.
It's located right behind the engine underneath the middle of the windscreen between the two struts?
Thanks i'll happily pay postage.
mintstuff said:
Hi foxy-stoat
Trim below hand brake is gone
Can hook out the two bits either side for you.
No ashtray as this has gone already.
Will dig it out later for you...if you can pm me your address, it would be good.
W
Do you have the plastic perimeter surround of the little compartment where the ashtray is? Also, do you have any black bolt covers that would be found in the main central section? So if you're sitting in the driving position, to the left of your left thigh, in the main section. I have one missing
I'll post pics when I can.
The round one? I think I have 1 left....the ashtray bit, is that the one at front or the rear?
Is there any chance I could get 2 or 3 of the metal clips that hold the gear stick surround in place please? I've not had any luck finding the part number for these bits.
They are attached to the bottom of the plastic bit highlighted below.
Yes basically, it covers where the bolts/screws are sitting.
As for the surround, it'd be the front. Where the traction control and tyre pressure buttons normally are. In that area. Thanks.
Will have a look later....pm me your address and I'll pop them in an envelope.
:thumbsup:
Cool...will get them in an envelope, if you PM me your address I can send them out.
Ebay auction 170994115063 is all I have left in that area.
foxy-stoat said:
mintstuff said:
Hi foxy-stoat
Yeah, I'll take it as the paint on mine is bubbling off! How much do you want for it?
