:headbang:
Decided to do an oil change in a bit of a rush. Upon removing the bolt I couldn't find a washer. I assumed this bolt had been replaced at some point and was a type that didn't require a washer. It appeared to have one moulded into the bolt.
So in my infinite wisdom, decided to leave the new washer off. Once I had finished I moved the car and found the old washer on the floor :headbang: :headbang:
Question - will I be ok without the washer? Or I must drain oil and replace with new washer?
Google says check it in a couple of days and provided there is no leak, I should be OK.
Just want to get opinion of the experts.
TIA
TIA
