Forgot crankhase breather hose
Rombbb
The one on top of valve-cover-cover (:-)) and inlet manifold.
Just finished a DIY Inspection II, started it up, let it idle for a minute, revved to 2000 RPM in a bid to bring down the somewhat high idle, let it idle a minute more and then noticed I forgot to plug in one side of the breather hose.
Camshafts and rockers were pretty dry (no oil) because of the valve clearance job just before. Does this breather hose have any influence on oil getting to the camshafts ? Like creating some positive or negative pressure needed for the oil to get upwards and get spilled around ?
If so, camshafts, rockers, shims and valve springs/stems could have been running completely dry for some minutes.
Nothing to do about it anymore and car runs fine, but just for completion's sake, does that breather hose influence oil circulation or is the oil pump alone enough to get the oil everywhere ?
Thanks !
Cant answer your question but why would the camshafts, rockers and I suppose shims be dry? Did you not oil everything while assembling?
