Footwell LED lights HELP!!!!!!!!
Smartbear
 a barn in Somerset
Jonny essex said:
I would like to install yet another Mod that I didnt purchase as a optional extra when buying the Zed, the footwell lights on both the near and off side.
They need to be LED so they are white not that dull yellow and have all the wires with them so i can run them from the modual behind the Glove box.
Does anyone have a e-bay link or know of anywhere I can purchase the required parts?
Cheers
:D
Hi mate, I've got the footwell lights on my zed if you need to look at the positioning etc :thumbsup:
Is the loom in place? Pop some LED strip in - I've been considering doing a kit but would only work if the loom is there.
Failing that an inline fuse, connect to light feed and job done?
There was an ebay link on the forum, bought a pair for less than £20. Straight swap for existing units. 10 min job.
Wiring was taped up and away on my car and took a bit of fiddling to find but was there. I am an early build prefacelift though.
Jonny essex said:
If the prefacelift model has the loom already then all models would have I would have thought!?
Might be worth a look- I took the panel off and the wires were taped to anther part of the loom further up.
Jonny essex said:
Were the plugs there so it was easy to see them?
Yep they were the only plugged wires up there
Cheers
:D
When I purchase the lights you can fit them then fella :lol:
I'm not very good at fitting in foot wells :rofl:
The footwell lights will just tag onto the cables we put in for your door sill lights, it's the same circuit :thumbsup: easy peasy.
Stuart
