Flying Objects.
Hunter
 notts/derby
Hey guys, The storage net that goes across the little shelf behind the seats...its bloody usless...it doesnt stay up (was going to say erect) and kinda sags on itself...anyone else got this problem? :o and any solution?
Just pull it up to the too of the rails that suspend it as it has dents to stop it going down. If yours is stretched or whatever you might need to put a bit of string around the net top and the dents in the rails. It's designed to be collapsible.
I think it's a common problem. Ours is the same. The plastic fixings at either end slide past the kink in the support rail too easily.
I guess it depends how far back you have the seat. We have so little room that ours doesn't get used so it's not really an issue.
One option would be to pop a cable tie round them to keep the net permanently erect.
(You could also drive at less than 88 mph ;) )
