Hi Russ many thanks for the tips, I have one question though , how do I open the hood to get at the wiring. It wont move because of the flashing red light ????
In the left hand side of the boot you will see a red plastic ring, pull and twist it to disengage the motor.
In the roof above the windscreen remove the plastic trim then you can unlock the roof from the windscreen with the Allen key you should have, then manually push the roof back, to the point where it just stops dropping down under its own weight.
