Started to fit my Intravee today after giving up on Friday trying to do in the dark.
Due to having OEM bluetooth first job was trying to get the cradle out. Asked PVR but his method seemed to difficult, but it may have just been lost in translation. So using TIS worked out how to seperate the cradle from the door. Used a couple of old credit cards and slide down each side to release. Doing this meant I could get everything out of the way so it wouldn't get damaged.
Having a CD changer makes life more difficult fitting the Intravee. As you cannot disconnect from the boot due to the battery being in the way it's easier to get to it from the front, but the DVD Nav drive is in the way. :headbang:
So the DVD drive had to come out, and as the leads are short and you need to be able to get to the Intravee so the Changer also had to come out. :headbang:
I'm waiting to find a storage tray to complete, but did manage to check it all works. I may also look at putting the changer back if I can locate the Intravee and alpine on the DVD mounting bracket and leave a flying lead to enable updates.
For those who have done this with DSP and maybe a changer, where did you locate everything?
